Cooking issue after cached!
   Views 428   Replies 2   Subscribers 0
Why the sim does cook even after the sim was file cached?
I don't remember which build had this bug, but if you upgrade to the latest production build this problem should resolve.
It could also be that there are some template flags between the sim and the cache node switched on. Or maybe you view "all objects" which could include merges etc. Worth checking all options.
If you just view the cache the sim should not cook, that is not normal behavior.
