Solaris Megascans USD Asset Builder + Karma Lookdev | Free HDAs
   591   0   0
My Houdini Solaris Megascans USD Asset Builder (MaterialX) + Karma Lookdev HDA's is now available on Gumroad for free.
Build a Megascans asset simply by selecting the folder that contains the textures and variants of the asset.
You can set the asset name, specify if the asset includes a proxy, normalize the size (maximum size is 1 meter), set the geometry and material save paths for the USD, and define the geometry and proxy paths to determine how they will be read in the scene graph. All of these parameters can be adjusted without needing to rebuild the asset.
Lookdev the Megascans asset in Karma render. Rotate the asset, offset it, change light exposure and launch an automatic render by just one click.This tool is asset-agnostic and can be used to lookdev any asset in Solaris, not limited to Megascans.
Hope you enjoy it!
https://pepebuendia.gumroad.com/l/csqcv [pepebuendia.gumroad.com]
Edited by pepebuendia - Sept. 13, 2024 02:11:01
Houdini FX/TD
