Hello everyone
Do you know if there is any plan about caustics in Karma ?
I would really like to switch my workflow to Houdini/Solaris, but as I mainly do commercial projects around perfume and alcohol bottles, I need to be able to handle caustics. For the moment I'm using Blender / Cycles, which is far from incredible for this use, but at least with the "Lightpath" node trick, I can have more or less control over the rendering of fake caustic, which often does the job. Maybe there is a similar trick in karma, but never see how to....
So for the moment, this lack of caustics or control over fake caustics, prevents me from professionally switching to this software that I really like...
Caustics in Karma ?
644 6 1- philippepetitpas
- 52 posts
- tamte
- 8730 posts
since Karma supports both pathtraced as well as fake caustics you may want to ask more specific question
do you have issue with it's speed, quality or do you have issues making caustic to work at all?
keep in mind that pathtraced caustics in Karma are mostly bruteforce, can be aided a bit by path guiding in CPU, but outside of that don't make use of any dedicated caustic sampler or unbiased photonampping techiques at the moment
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- philippepetitpas
- 52 posts
You’re right, it’s not really specific
So, can we expect any dedicated caustic sampler or unbiased photonmapping ?
Other question, how can we customize the fake caustics ?
I tried to do it like I do in blender : one glass material, one « transparent material (I don’t know how to do it with material x so I create a glass material with an ior of 1), then I tryed to made the dot product of normals and different things import with « ray import » (don’t know how I can import « incoming » like in blender), connected to a ramp, connected to the transmission color, but it wasn’t really working…
How do you guys do ?
(You can see the trick at like 30sec :
Edited by philippepetitpas - Sept. 16, 2024 01:39:22
- ali_f
- 42 posts
There is no dedicated sampler for caustics in Karma yet.
However, you may take a look at Render Geometry Settings for caustics and fake caustics options which give control
over enabling/disabling caustics, the fake caustics color and opacity:
https://www.sidefx.com/docs/houdini/nodes/lop/rendergeometrysettings.html [www.sidefx.com]
- philippepetitpas
- 52 posts
- jsmack
- 7992 posts
philippepetitpas
Yes I already saw that, but I want/need more control over fake caustics ? Can’t we access it by a different path, a bit like in blender where you can control the shape and brightness off it ?
You can easily do this with a vex material. I'm not sure if there is the state information to do a ray switch on shadowray with MaterialX though.
- philippepetitpas
- 52 posts
