ACES default view transform
   1261   1   1
Hello.
How could I change the default view transform for the viewport and Mplay only?
Every time I launch Houdini, the view transform is set to un-tonne-mapped, even if I change it to ACES 1.0 SDR-video in the OCIO Editor during a previous Houdini session.
I know I can edit the .ocio file in the Houdini config folder, but when I do that, I encounter some errors with Redshift during rendering.
I'm using Houdini 20.5.322 and Redshift 2025.0.2
You could do it with some python to automatically run on start-up. Under Color Correction, hou.SceneViewer has a method called setOCIODisplayView() which should do what you want.
https://www.sidefx.com/docs/houdini/hom/hou/SceneViewer.html#flipbookSettings [www.sidefx.com]
