onKeyEvent issue (python)
   Views 997   Replies 4   Subscribers 4
hi
I am writing a HDA python viewer state.
I would like to do something when the "r" key is pressed.
I wrote this python line to do that:
self.key_pressed = ui_event.device().keyString()
if self.key_pressed == "r":
    self.node.parm("color").set(0)
but when I test the HDA and press "r", it active the "rotate" tool instead of staying in my view state.
how can I avoid it?
Edited by Gerardo Castellanos - Sept. 16, 2024 16:52:49
Gerardo Castellanos
www.gerardocastellanos.com
Houdini has a bunch of magical keys(ERTYS) locked into their viewport/modeling/edit workflow that for some reason has priority over everything else in the software and can’t be overridden.
I hoped maybe the new hotkey system with 20.5 would free these keys but I haven’t looked into this yet. Otherwise tough luck, send another RFE, SideFX knows but it might take a few years for things to change.
Edited by aeaeaeae - Sept. 17, 2024 03:10:36
B-System for Houdini [ae43ae43.gumroad.com]: instance editor, blender like interface.
The new hotkey system in 20.5 does indeed give state hotkey contexts priority during hotkey resolution. However, to take advantage of that, you need to use the hotkey system, i.e., register a hotkey context symbol, hotkey action symbols, and default key bindings for that hotkey context. Without that you're at the mercy of the hard-coded order in which various key event handlers are triggered by Houdini. It also good practice to do in general so that key bindings can be customized through the hotkey manager.
I think the examples/documentation are still a little behind in this respect, so the easiest way to see an example is to look at one of the python states we're shipping. For example, $HFS/houdini/viewer_states/sidefx_clip.py. The way it's done there is designed to work under both the old and new hotkey systems in 20.0 and up, though of course the new system is only used by 20.5 and up.
What you're looking for is the use of the `hou.PluginHotkeyDefinitions` object to register the various hotkey symbols and default bindings with the viewer state template in `createViewerStateTemplate()`.
In the `onKeyEvent()` function, you'll want to note how `viewerstate.utils.hotkeySymbolOrKeyString()` is used instead of the raw key string from the `ui_event`, and compared against a hotkey symbol using `hou.hotkeys.isKeyMatch()`.
Edited by Ondrej - Sept. 19, 2024 10:24:33
How did you intend to handle hotkey conflicts internal to the same viewer state. I have a complex viewer state where the same hotkey does different operations. I use the 'x' key both to delete, and when dragging an item toggle snapping to the x-axis.
I tried creating a subcontext for 'snapping', such as `h.pane.gview.state.myViewerState.snapping`, but only commands in the main `h.pane.gview.state.myViewerState` context seems to bubble up in the onKeyEvent kwargs.
Is there some way of setting the current hotkey context in the viewer state?
Edited by aeaeaeae - March 24, 2025 07:35:35
new callback dropped:
From our developers:
By default, python states will only use the "default", i.e., first, context they were registered with, which will typically be h.pane.gview.state.sop.myThing. To control which combination of contexts is used by your state at any given time, you need to add another handler to your python state.
def onKeyGetResolveInfo(self, kwargs):
contexts =
if use_snapping:
contexts.append("h.pane.gview.state.sop.myThing.snapping")
contexts.append('h.pane.gview.state.sop.myThing')
kwargs = contexts
This handler is called for the current state whenever Houdini needs to build the lists of contexts to resolve against.
