Vellum collision detection
   355   1   0
I can see I'm not the first one to ask this, but I haven't seen a good answer anywhere.
I've got a vellum setup with multiple colliders and need to track particle age off collision with one particular collider. But none of the collision attributes seem to update. Hitnum remains at 0 regardless of collisions.
I've tried both SOP solver and DOPs, and both seem to be the same.
Anyone found a way around this?
Aside from the more immediate question, is there also a way to record which object collided so I can chart time based off that collision? Is there no hitpath in vellum?
Edited by made-by-geoff - Sept. 19, 2024 21:42:09
madebygeoff.com
Adding a POP collision detect node to the Sources pipe in either SOPs or DOPs works.
madebygeoff.com
