python states and setAttribValue
   1037   4   1
Hello
I am working in a HDA, and using Python Viewer States... I would like to modify (write) a primitive attribute (primnum 0 for example) with the mouse wheel.
so my code is:
    def onMouseWheelEvent(self, kwargs):
        ui_event = kwargs["ui_event"]
        state_parms = kwargs["state_parms"]
        dev = ui_event.device()
        self.myValue += dev.mouseWheel()/100
        myPrim = self.node.node("myNode").geometry().prim(0)
        myPrim.setAttributeValue("myAttr", self.myValue)
but it gives me an error:
... AttributeError: 'Polygon' object has no attribute 'setAttributeValue'
but the polygon class has that method, why it does not work?
how can I do write values on primitives using python viewer states?.. any advice?
Thanks you
I
Gerardo Castellanos
www.gerardocastellanos.com
Maybe setAttribValue instead of setAttributeValue will work?
https://www.sidefx.com/docs/houdini/hom/hou/Prim.html [www.sidefx.com]
Gerardo Castellanos
the method is called setAttribValue()
However even with correct method call I assume you will get permission error as its not allowed to modify geometry of SOP nodes with external scripts,( only Python SOP can modify its own geo during its cook)
So you may want to consider modifying a geometry stashed in a data parm on your HDA which can be then referenced in internal Stash SOP for example
FX Supervisor
Method Studios, NY
ohh yep.. my bad, sorry... but even with the setAttribVale()... it says:
hou.GeometryPermissionError: Geometry is read-only.
as I said, I am running this script from a a Python HDA states... how can I modify it if it is read-pnly?
Gerardo Castellanos
Gerardo Castellanos
https://www.sidefx.com/forum/topic/98033/#post-430783 [www.sidefx.com]
FX Supervisor
Method Studios, NY
