PDG/Deadline -> Fail Task = Endless Loop
   497   0   1
The short of it -
How do I override a Deadline Job's Properties for failure detection from the Deadline Scheduler?
Deadline Failure Detection Docs [docs.thinkboxsoftware.com]
Long of it -
I'm submitting PDG Python Script Work Items to Deadline via the DeadlineScheduler. Each Work Item gets it's own job, containing a single task within (not using "Submit As Job" option, just cooking out-of-process tasks via DeadlineScheduler)
There is a condition in the Python Script that fails the task -
work_item.addError('Fail Note', fail_task = True)
After the condition is hit, the error is thrown, the task fails, HOWEVER... the same task re-queues itself in Deadline and does not fail the job. The work_item.addError condition is met again, task fails, task requeues, endless loop.
How do I get the deadline JOB to fail if the addError condition is met?
Looking at the Manual Job Submission [docs.thinkboxsoftware.com] options available, I see a few for "Failure Detection" -
I've attempted settings these job parameters in multiple places around the Deadline Scheduler and they do not pickup in Deadline -
So how do I go about failing the Job when the single job's task fails via work_item.addError(fail_task=True) and not have just an endless loop of the same failed task requeuing itself?
Thank you for any help / input.
Edited by krause_trk - Sept. 24, 2024 17:06:45
