Hi!
I'm using Houdini 20.5 and need to submit a PDG network to a Deadline render farm. The farm is working, and I've successfully managed to send the TOP network to be executed as a job on the farm.
However, by default, it submits everything as a single job, with all work items running within that job on the same machine. Is there a way to configure the Deadline Scheduler so that each work item is submitted and executed as a separate job, potentially running on different machines? I've been searching for a solution but haven't been able to figure it out.
Thank you for all!
Send one job per work item to deadline in a PDG network
819 5 3- emunoz
- 3 posts
- HristoVelev
- 82 posts
- Boning
- 18 posts
- HristoVelev
- 82 posts
- emunoz
- 3 posts
Hi!
After some trial and error i found a solution. It's very simple, but it can be a little confusing at first.
I'm using Houdini 20.5, in previous versions the behaviour might be different, as indicated in the second note in the documentation page (Deadline Scheduler TOP docs [www.sidefx.com]
What i wanted was for each work item to be executed as a separate job on the farm. For that, I need to set the Default Scheduler of the topnet to a deadline scheduler (the one inside the network) You need to check the Inherit Local Environment in the deadline scheduler (Job Params tab > Deadline Command Environment)
With those two settings, when the top network is cooked, each work item is sent to the farm as a separate job.
I hope this helps if any one is having a similar problem.
- HristoVelev
- 82 posts
