Transparency showing up in the Normal AOV. Is that normal?
   275   0   1
Hi.
I have a sky text on material assigned a mesh. The material has transparency on it via the blue channel of the sky texture connected to transmission slot of the mtlxsurface unlit shader . But looking at the normal AOV pass I can still see the transparency, same with depth and cryptomatte. Is that normal?
Is the AOV not suppose to just read raw geometry normals(Maybe with a displacement map prepass if chosen so)?
Edited by Leozard - Sept. 25, 2024 13:56:56
Transparency in AOV.png (386.9 KB)
