poligon curves and bezier curves
602 4 0- Fernando_Criativo3d
- 9 posts
- tamte
- 8759 posts
- 9 posts
- tamte
- 8759 posts
Fernando_Criativo3dCurve SOP can hold mixture of primitive types, even within one you can draw first curve as Poly, then switch type to Bexier therefore next curve will be drawn as Bezier, keeping the first one as Poly
I thought that once the Bezier curve is added it will become a Bezier not a polygon.
meaning the Primitive Type parameter is not changing the type of existing curves and therefore it doesn't represent the type of the output geo as a whole
what may be missing in Curve SOP though is a way to select curves and convert to different type interactively, hence for now the Convert SOP workaround
Edited by tamte - Sept. 27, 2024 12:49:52
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Jikian
- 144 posts
