Projecting shape on layered surface
   Views 467   Replies 1   Subscribers 0
Trying to project a shape on a surface with multi-layers.
In a particle system, the particles will not move in relation to the layers. They will project a shape on the nearest surface.
Sometimes the shape is tilted, projecting on partially between two layers.
I setup each shape to project a center to a surface, and than get the neighbor points on that surface so I can create a temporary plane to project. But the vex I have is not efficient, so I would like to ask for an alternative.
projection1.hiplc (123.4 KB)
Solved with vex and help from space...
Screenshot 2024-10-02 at 11.52.00.png (1.2 MB)
projection2.hiplc (113.0 KB)
