VEX : array question.
   520   3   1
using an OSM file I am trying to get all intersection points in an array. "intersectionanalysis" does not work because the "Proximity tolerance" is or too high or not enough.
So I am trying to find all cross points like this :
int nc = neighbourcount(0, @ptnum);
i@nc = nc;
int ptid = @ptnum;
i@ptid = ptid;
int ptcount = @numpt;
i@ptcount = ptcount; // just to check
int intersectionList = array();
for(int i = 0; i < ptcount; i++)
if (nc > 2){
i@intersectionid = 1;
int intersectionid = @intersectionid;
append(intersectionList, ptid);
i@il = intersectionList;
...but of course i am not getting what i expect...i got something like this
Any good tutorial or help ?
Thanks !
Probably because the array variable is missing brackets []:
int intersectionList[] = array();
Same thing when you want to write into an attribute using @-syntaxe :
i[]@il = intersectionList;
ObeidaZakzak
Hello thanks but no... in fact when i copied the text i forgot to use the "vex" tag here and so it seems the system delete the brackets.
So here it is the full code now:
i@nc = nc;
int ptid = @ptnum;
i@ptid = ptid;
    if (nc > 2){
All right I took a closer look at your script.
Are you running this over Points or Detail ?
If it's over Points, then you will get a long array on every point, due to the fact you are looping over points inside a Point Wrangle. Also when working with a huge data set you might encounter performance issues due to the for loop.
If it's over Detail, then it should not work at all because @ptnum does not have sense in a Detail Wrangle, it's only usefull when running over elements like Points/Vertices/Prims.
Now if I understand the problem you are trying to solve, you want to build an array of point IDs where they have more than 2 neighbours, right ? If it's so, I can suggest a couple of methods here, and you could adapt them to your problem :
1. Build everything with a Detail Wrangle :
i[]@intersectionList = array();
for (int pt = 0; pt < @numpt; pt++)
    int nc = neighbourcount(0, pt);
    int intersectionid = nc > 2;
    setpointattrib(0, "nc", pt, nc);
    setpointattrib(0, "intersectionid", pt, intersectionid);
    if (intersectionid)
        append(i[]@intersectionList, pt);
2. Assign point attributes with a Point Wrangle then build the list in a second time with a Detail Wrangle :
2a. Point Wrangle
i@ptid = @ptnum;
i@nc = nc;
i@intersectionid = nc > 2;
2b. Detail wrangle
    int intersectionid = point(0, "intersectionid", pt);
    if (intersectionid)
3. Same as 2. but instead of Detail Wrangle remove points where intersectionid == 0 and promote their ID to an array using Attribute Promote SOP (see in the hip file)
IntersectionList.hiplc (124.2 KB)
