Hard edges to edge group?
   658   4   0
Hi!
If I have a geo with vertex normals, is there a way to get an edge group containing only the hard edges? Currently, I have a way to group all the points that have different vertex normals but when I use the group_promote sop, I get some problem areas.
Also, I DON'T want to group by edge angle. I want to group edges purely by the vertex normals already existing on my geo.
-Olivier
Edited by olivierth - Oct. 4, 2024 16:52:41
have you tried using "N" with the group from attribute boundary node?
arg... sadly, that doesn't work.
Edited by olivierth - Oct. 5, 2024 01:19:44
Here is one way which should work:
for each edge (point pair) -> get both half edges -> get both prims (for each half edge) -> get all vertices for each edge point -> find for each prim the corresponding vertex for each vertexlist -> now you have two vertex pairs for each point containing the vertices of both prims -> now you can compare the vertex normals and if the angles of both pairs are greater than a threshold value put the edge into the group.
Edited by Aizatulin - Oct. 5, 2024 03:49:51
Play with this.
//#include <hedgedeep.vfl>
int hedge_nextequiv = hedge_nextequiv(0, @elemnum);
if ( chi("../includeunshared") ) {
    if ( @elemnum < hedge_nextequiv || hedge_nextequiv == -1 ) return;//includeunshared
} else {
    if ( @elemnum <= hedge_nextequiv || hedge_nextequiv == -1 ) return;//excludeunshared
// int hedge_dstpoint = vertexpoint(0, hedge_nextequiv);
int hedge_dstpoint = hedge_dstpoint(0, @vtxnum);
// printf('\n%d', hedge_srcpoint);
// if ( hedge_dstpoint != 57 ) return;
// printf('\n%d', @ptnum);
string edgeGrps[] = split(chs("../edgeGroup"));
foreach(string edgeGrp; edgeGrps) {
    if ( !inedgegroup(0, edgeGrp, @ptnum, hedge_dstpoint) ) return;
vector posdst = point(0, 'P', hedge_dstpoint);
vector dir = normalize(posdst - v@P);
float dot = dot(dir, normalize(chv('../dir')));
dot = chi("../bidir") ? abs(dot) : dot;
i@outgrp = ( dot > chf('../threshold') ) ^ chi("../reverseGroup");
hedgedeep.vfl (5.4 KB)
Conservation of Momentum
