Is it possible to export an FBX Character with all the rotations zeroed out on the joints as I want to import into Maya to complete my rig which ideally needs all the rotations set to zero. I can transfer all the rotations to the joint orient attribute in Maya manually but I was hoping there is a clever way to do in Houdini beforehand.
Thanks & Regards,
FBX Character output
882 3 1- sutcliffe
- 22 posts
- edward
- 7899 posts
- sutcliffe
- 22 posts
Thanks for taking the time to reply @edward. I think I understand what's going on however when I plug in my skeleton everything goes a bit wonky/: I thought it might be something to do with rotation orders but changing those didn't make any difference. Without wishing to over-reach, could I please ask for your assistance on more time?
I'm a bit surprised that this wouldn't be a bit more straightforward as I would have though exporting a skeleton with zeroed out rotations would kind of the be the norm?
- edward
- 7899 posts
Ah, it only worked in my case because I didn't notice that the Mixamo skeleton was authored such that the joints are aligned in world space in the T-pose! So given, just correctly aligned joints your skeleton here is already at its "rest pose". So I don't think anything can be done on the Houdini side. Your process of "freezing" the joint rotations in Maya sounds like the best approach to me.
