Matrix transformation - lacking rotation.
   424   1   1
I am trying to learn how to use matrix in my workflow and am getting a little bit stuck.
I have a group of packed objects and want to replace them with other packed objects using the same position and rotation and scale.
So far I can get the objects to match in position but not in rotation. This is the code I am using, and attached is some screenshots.
matrix m = primintrinsic(0, "packedfulltransform", @ptnum);
matrix m2 = primintrinsic(1, "packedfulltransform", @ptnum);
v@P*=invert(m)*m2;
Instead of transforming @P, which will only apply translation, use packedtransform() which will adjust P and the intrinsic transform for rotation and scale.
https://www.sidefx.com/docs/houdini/vex/functions/packedtransform.html [www.sidefx.com]
