Saving custom variables with HIP-file
542 4 2- Flowww_Studio
- 11 posts
Hello, i am currently trying to set up a simple shelf tool that allows the user to select some directories, and save the paths as variables like $CLIENT $SHOT $ASSETS etc. Everything is working fine, but the variables are not saved with the hip file, so i have to set them again every session. I am using "hou.putenv" to create the variables, is there a way to make them save with the hip file, or another approach to achieve the same effect?
- erikcarlson
- 25 posts
- Flowww_Studio
- 11 posts
- ajz3d
- 580 posts
- Flowww_Studio
- 11 posts
ajz3d
Have a look at Context Options [www.sidefx.com].
This also seems like it would work. Apart from having to use @ instead of $, do you know if there are any functional differences between the two ways of doing things (context options vs environment vars)? Or is it just a use whatever is easier situation?
Thank you for the guidance.
