hou.hipFile.save very slow
   387   1   1
I'm running into an issue where running
hou.hipFile.save(path)
is very slow (about 4 - 5 minutes).
I've tried both on a local and network file system and it doesn't really change, so I don't think it's a hardware issue.
I've also tried running performance monitor right before saving, but it doesn't seem to record what's happening during the save process.
The HOUDINI_BUFFEREDSAVE environment variable is set to 1.
len(hou.node('/').allSubChildren(recurse_in_locked_nodes=False))
is 634. Doesn't seem like a ridiculous number of nodes that would cause a lot of slowdown to me.
How else can I profile this?
Another thing I noticed is when I save as v001, it will take about 4 minutes, but if I save again as v002, it takes about 3 seconds, so this is leaving me scratching my head.
Currently testing with Houdini 20.0.688 on Windows 10.
Edited by erikcarlson - Oct. 14, 2024 21:49:35
If you have any nodes locked with geometry, that could be what is slowing things down. Is your HIP file size huge?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
