VEX String: add space after each 3 letters?
   636   6   1
Hi!
Lets say I have a string:
jghweiauhoigafawgeu
But I want a space at every three letters like this:
jgh wei auh oig afa wge u
Any simple solution? My other option is a for loop but I'm curious to see a simpler way.
-Olivier
string s = "jghweiauhoigafawgeu";
string new_str = join(re_findall("[a-z]{1,3}", s), " ");
Edited by alexwheezy - Oct. 30, 2024 13:26:31
You can do this using regex easily:
string input = "jghweiauhoigafawgeu";
string result = join ( re_findall (".{1,3}", input ), " " );
Submitted - BUG #142040.
To review vex function web help page.
Update and review tags for all functions.
e.g. re_find() function - listed under strings section when filter drop down set to 'All tags' : But not listed under strings section when filter drop down set to strings(#of).
Fantastic!
Can you explain exactly what
[a-z]{1,3}
and
.{1,3}
do exactly?
-Olivier
Edited by olivierth - Oct. 31, 2024 11:05:41
[a-z]{1,3}
Matches any consecutive occurrences of characters from "a" to "z" range (case-sensitive) one to three times. It's greedy, meaning that it will keep on matching until it finds a character outside of a-z range, or it finds three consecutive occurrences of a-z characters. In both cases it will start a new matching operation.
jGhw eia-uhoigafawgeufs
0-1 j
2-4 hw
5-8 eia
9-12 uho
12-15 iga
15-18 faw
18-21 geu
21-23 fs
.{1,3}
This is the same as above, but operates on any character (.). Note that it will match whitespace.
0-3 jGh
3-6 w e
6-9 ia-
9-12 uho
12-15 iga
15-18 faw
18-21 geu
21-23 fs
Ah! Thanks for the full explanation. I apriciate that!
-Olivier
