I'm having trouble coming up with a network to process meshes.
Tldr; I want to automate fixing UV issues created by a bevel modifier in my DCC.
I have a "source" and "target" mesh, which I'm transferring UVs in between using the Labs Transfer UV node. My plan was to use a TOP network to automate the import and export of a whole bunch of meshes.
What I cannot figure out is how to set up the filePattern node to split between a "source" and "target" mesh. I've tried 2 streams of filePattern node but it didn't work as one stream is not fed to my fileImport node. So currently I have this setup, but I noticed the work items are being multiplied in my 2nd filePattern node..
Hope to get some advice on how to go about this.
TOPs Network with non-generic file names
297 1 1- LearningPointCloud
- 7 posts
- 7 posts
Update: I think my question was hard to understand. Essentially I wanted to use the filePattern TOP node to filter between 2 types of files based on a prefix name. Also I wanted to store the work items generated from 2 filePattern nodes and to pass them over to 2 fileImport SOP nodes.
In the end, I just used 1 filePattern node to grab the `target` files and through hscript (strcat) appended the prefix name for the `source` files import. This simplified my setup and it all works now.
