Hey guys,
I noticed when a houdini file gets bigger, houdini tends to freeze much more often.
My current scene file (Houdini 20.5.370) contains ten separate shots, its size is about 25 MB. And now when I only want to select one of these shot networks in the top hierarchy level it immediately doesn't respond anymore. That's although neither my CPU nor RAM is used to capacity, so I guess this can't be a hardware problem.
Of course there is a huge number of artists in the industry who have much bigger projects than I do. Do they always split all their files per each individual shot? Or do you know yet another way that may simplify optimazation between the shots to deal with this?
Work with big files
808 6 1- freewind
- 94 posts
- Enivob
- 2630 posts
- jsmack
- 8045 posts
- boning
- 19 posts
- freewind
- 94 posts
Thanks for your experiences. I also think that 25 MB shouldn't be that much of a problem.
Even the performance monitor seemed to freeze when I tested that. I figured its values are getting updated every 60 - 90 seconds in my scene. Actually there's a lonely leader in terms of time consumption.
Sometimes the loading of that mesh seems to be a big problem. But I can't tell why, its filesize is only 7 MB per frame. It's always the same mesh with animated Cd.
Currently I'm lucky enough to have the right objects selected and visible in the scene view. But I'll certainly becom desperate when this happens again.
Intel core i7 6700K
64 GB DDR4 RAM
Nvidia GeForce RTX 3060
Intel core i7 6700K
64 GB DDR4 RAM
- johnmather
- 530 posts
- freewind
- 94 posts
