Vellum tetrahedral + weld points - welds dont want to break
   497   3   1
Hi
I am trying to create a vellum softbody object that falls apart on impact.
I have my pieces with tetconform and tetrahedral constraints. Then add a weld on the edges of the outer shell.
For some reason the combination of tetrahedral and weld points makes the welds unbreakable.
It's important I use tetrahedral for this project.
Any ideas why this might be happening?
houdni_head_stripped.hiplc (889.7 KB)
to break weld constraint 'weld' point attribute on a geometry (not constraint) has to have value -1.
I.e. vex code:
if(@Frame>9) i@weld = -1;
in a popwrangle dop should work in your example.
vicvvsh
I.e. vex code:
Thank you for the input, your solution is equicalent to just turning the welds off so not really what I am looking for.
I want to break the welds based on the stretch stress etc. It works really well with struts but somehow in tetrahedral it doesn't I am not really sure why.
pitapan
vicvvsh
I.e. vex code:
There is no stretch stress generated from tetrahedral constraints, as a workaround you can add Distance Constraints at least to the outside polygons which are welded and set it's Stiffness to 0
That way it should not affect your sim but you should be able to use Stretch Ratio it Stretch Distance breaking type on welds
FX Supervisor
Method Studios, NY
