I want to load an animation mesh created in 3dsmax into HDA.
   Views 2997   Replies 0   Subscribers 1
Hi.
I am trying to store Pyro Simulation in HDA and run a smoke simulation using Houdini Engine in 3dsmax.
I tried to import the animation mesh created in 3dsmax as a collision or emitter. However, the mesh did not animate.
I used Object Merge and Subnet input to import these, but the movement stopped at the imported frame in both cases.
How do I load the animation mesh created in the 3dsmax scene into the HDA that is started in the 3dsmax scene and use it as an emitter or collision?
Thank you.
