Houdiniをインストールした直後は問題なく起動できていたのですが、数日経って起動しようとすると下記エラーが発生して起動できなくなりました。
一度アンインストールし、再度インストールし直した時も、始めは起動が出来るのですが、間を空けると同様のエラーが発生して起動できなくなります。
Error running event handler:
File "Sop/heightfield_drawmask, ViewerStateModule", line 4, in <module>
File "C:\Program Files\Side Effects Software\Houdini 19.5.682\python39\lib\site-packages-forced\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'sidefx_stroke'
File "Sop/heightfield_drawmask, opdef:/Sop/heightfield_drawmask?ViewerStateInstall", line 1, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.682/houdini/python3.9libs\viewerstate\utils.py", line 969, in register_pystate_embedded
raise ViewerStateException("createViewerStateTemplate not found in {}".format(node_type.sourcePath()))
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/heightfield_drawmask?Sop/heightfield_drawmask
File "Sop/heightfield_paint, ViewerStateModule", line 8, in <module>
File "Sop/heightfield_paint, opdef:/Sop/heightfield_paint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/heightfield_paint?Sop/heightfield_paint
File "Sop/attribpaint, ViewerStateModule", line 6, in <module>
File "Sop/attribpaint, opdef:/Sop/attribpaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/attribpaint?Sop/attribpaint
File "Sop/groupbylasso, ViewerStateModule", line 5, in <module>
File "Sop/groupbylasso, opdef:/Sop/groupbylasso?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/groupbylasso?Sop/groupbylasso
File "Sop/rbdpaint, ViewerStateModule", line 6, in <module>
File "Sop/rbdpaint, opdef:/Sop/rbdpaint?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/rbdpaint?Sop/rbdpaint
File "Sop/shotsculpt, ViewerStateModule", line 13, in <module>
File "Sop/shotsculpt, opdef:/Sop/shotsculpt?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/shotsculpt?Sop/shotsculpt
File "Sop/vellumbrush, ViewerStateModule", line 9, in <module>
File "Sop/vellumbrush, opdef:/Sop/vellumbrush?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/vellumbrush?Sop/vellumbrush
File "Sop/fibergroom, ViewerStateModule", line 10, in <module>
File "Sop/fibergroom, opdef:/Sop/fibergroom?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/Sop/fibergroom?Sop/fibergroom
File "kinefx::Sop/adapttoterrain, ViewerStateModule", line 3, in <module>
ModuleNotFoundError: No module named 'kinefx'
File "kinefx::Sop/adapttoterrain, opdef:/kinefx::Sop/adapttoterrain?ViewerStateInstall", line 1, in <module>
viewerstate.utils.ViewerStateException: createViewerStateTemplate not found in oplib:/kinefx::Sop/adapttoterrain?kinefx::Sop/adapttoterrain
Houdini 19.5.682起動時にクラッシュする
663 2 0- YasuYasu
- 2 posts
- Ken Taki
- 391 posts
My Documents 以下にある houdini19.5 というディレクトリを別名にして Houdini を再度起動してみて下さい。
これで起動できれば、初期設定ファイルの中に何かエラーがあるということになります。
起動できたら、 こちらの要領で診断情報を出力してみてください。
https://www.sidefx.com/ja/faq/question/444/ [www.sidefx.com]
再び問題がありましたら、このマシン情報を info-jp@sidefx.com に送ってください。
取り急ぎ宜しくお願い致します。
取り急ぎ宜しくお願い致します。
- YasuYasu
- 2 posts
