How to transfer Cd Attrib from Point Cloud to Volume (help)
   127   1   3
Hi everyone,
I’m trying to transfer the color attribute Cd from a point cloud (representing an image) to a volume, but I’m running into issues. The main problem is that the color information is desaturated when I attempt the transfer—it appears grayscale instead of maintaining the original RGB values.
I’ve tried a few different setups, but I can’t seem to get the color to transfer correctly into the volume without losing the saturation. Does anyone have any tips or know the correct approach for this?
Thanks for the help!
What are you using to get the color into a volume? Is the volume a vector-type VDB fog volume?
To get a color volume to display correctly in the viewport you'll want to use a Volume Visualization SOP with the color volume you created (typically Cd) set as the Diffuse Field. You'll also need a density scalar volume for the overall opacity.
color_volume.hip (349.9 KB)
