"Do you know how to insert arbGeomParams in a specific location to export a particular detail value?"
This is maya to houdini alembic original file.
Hierarchy in Alembic File:
Object: ABC
Property: .childBnds
Property: statistics
ScalarProperty: statistics
Sample 0: PolyAnimNum 202 PolyAnimCVs 224681769 PolyAnimFaces 618863 TransStaticNum 266
Property: 1.samples
ScalarProperty: 1.samples
Sample 0: 351
Object: robotarm:robotarm
Property: .xform
CompoundProperty: .xform
Property: .arbGeomParams #-----------------------------------------------------------
CompoundProperty: .arbGeomParams
Property: ver <---------
Property: .userProperties
CompoundProperty: .userProperties #-----------------------------------------------------------
This is houdini to maya export alembic original file.
Object: robotarm:robotarm_hi_lf_part_a_metal_a
Property: .xform
Property: .inherits
ScalarProperty: .inherits
Sample 0: True
Property: .ops
ScalarProperty: .ops
Sample 0: 48
Property: .vals
Property: visible
ScalarProperty: visible
Sample 0: -1
Object: robotarm:robotarm_hi_lf_part_a_metal_aShape # -------------------------------------------------
Property: .geom
CompoundProperty: .geom
Property: .selfBnds
Property: P
Property: .faceIndices
Property: .faceCounts
Property: ver_test
ScalarProperty: ver_test <------------
Sample 0: v777
Property: uv
CompoundProperty: uv
Property: .vals
Property: .indices
Property: N
Property: visible
Sample 0: -1 # -------------------------------------------------
Object: robotarm:robotarm_hi_lf_part_a_metal_b
I have a path primitive value in Houdini, with Build Hierarchy From Attribute checked in the ROP Alembic Output node, and Path Attribute set to path for export.
I'm exporting a ver_test detail attribute, and I want to attach this detail value to robotarm:robotarm, matching the original .abc file that came from Maya. Does anyone know how to do this?
help.... ~~
How to export alembic to maya insert arbGeomParams.
59 0 0- yang simon
- 1 posts
