Could someone help to sort a bunch of curves procedurally?
   756   4   2
hi all! I have 12 curves that rise up the Y axis and fan out over x and z. Some of their point orders are reversed. Ideally I would like the highest point number to be at the end of the curve, away from the origin. I can do this using the sort node on individual curves, but I cant figure out how to do it procedurally on the whole bunch. I want to avoid having to re-select the reversed curves if I need to change the curves further up my graph.
Over to you guys! All help appreciated!
Dave
You could create an attribute based on the points UV on its' prim with the vex function xyzdist()....and use that attribute in a sort SOP.
1.create a root group using a bounding sphere 2.add distance along geo node to calculate @dist from the root group 3.Then use for each loop and a sort node to sort by @dist
1. Primitive Wrangle:
int pts[] = primpoints( 0, @primnum );
vector P0 = point( 0, "P", pts[0] );
vector P1 = point( 0, "P", pts[1] );
i@group_reverse = length(P1) < length(P0);
2. Reverse SOP - Source Group: reverse
3. Sort SOP - Point Sort: By Vertex Order
Edited by tamte - Nov. 14, 2024 14:58:05
FX Supervisor
Method Studios, NY
This is great thank you all for taking the time to reply. I'll try to implement this later today.
Thank you!
