Hi all,
Is there a quick and easy way to get an ambient occlusion pass for a groom? I see there’s the Labs "physical_ambient_occlusion" node, but it just turns my groom black, while my mesh (at the same scale) gets a nice occlusion pass. I suspect occlusion on groom curves isn’t supported yet, or maybe I need to set one of the parameters differently? Do you know if there’s a workaround?
Ultimately, I’d like to add the occlusion pass into a vector attribute (for RGB packing).
EDIT: I was able to get some AO on my groom by setting "Ray Offset" to .1 with the Labs physical_ambient_occlusion node. Must be something with how the occlusion is calculated on high detailed objects? Per SideFx doc.
Ambient occlusion on my Groom?
405 1 1- RogerRidley
- 2 posts
- olivierth
- 1075 posts
