Acescg exr output?
   Views 733   Replies 3   Subscribers 1
I had an issue that my .exr's renders did not match the viewport/mplay when I open them in Nuke or Resolve. I'm using Houdini's built in Aces setup.
They only match when I add the husk command --ocio 0.
Why is that, it seems abit counter intuitive. Or am I doing something wrong?
I can't see your rule for ".exr" but it's probably set to Linear Rec709 or something. Either change it, or in your output filename add "ACEScg" token so it matches the appropriate rule.
freshbaked
You can also explicitly set the output colorspace on the Karma render settings node.
jsmack
freshbaked
Thanks alot! Cant believe I missed that, now its works fine.
