Hello eyeryone,i have done a disintegration of an object,both primary and secondary RBD debris ive got.Secondary rbd debris (concrete_fracture2) needs to be scaled down to zero (dissappear)over time.Attaching the file.
the new clip. there enterily work easy in clip sop. in fx thing, the poit about what is the common acept about the good all. you can delete the primitivs. you can use boolean is a goood thing, you can use noise and color, the debris exist one second, hoy you show the thing, i think you in ten time, how you made again one second, clip sop, in noise is espectacual for dragon ball essence what about debris, maybe just again de same sequence becouse the peple i feel wait for artis in all aspect, be good mean
