Husk --postframe-script requiring a license?
   362   2   1
I'm running into issues trying to pass husk a postframe-script via the USD Render Rop Husk Post-Frame Script input.
Without it, the renders complete normally.
With it, the render errors after the first frame, with the following entries in the log:
[15:55:57] Running postframe script: W:/testing/houdini/husk/script.py
[15:55:57] No licenses could be found to run this application.
Does Husk require an extra license when running these scripts?
I'm running Houdini 20.5.278 on an Indie license.
I've updated my license server, and rendering is fine when no scripts are set.
Thanks in advance for any help/info on this!
There were some small fixes made to Python scripts in husk in recent months. I believe the most recent was in 20.5.398, so it might be worth trying a more recent build.
https://www.sidefx.com/changelog/?journal=20.5&categories=&body=husk&version=20.5&build_min=20.5.278&build_max=&show_versions=on&show_compatibility=on&items_per_page= [www.sidefx.com]
Ah yes, that did the trick. Can confirm that's fixed in a later version.
Thanks for the reply Mark.
