Image Magick converting .ARW Files from a Sony Alpha 7R IV
   1358   0   0
Hello
i was trzing to make image magick work with some sony arw files. When i use the example scene of the imagemagick node in TOPs and feed in TIFs everything works fine. But if i feed in .arw files it gives this error:
Executing command: magick convert -background black "C:/Users/Josh/images/imagemagick2_304.jpg"
WARNING: The convert command is deprecated in IMv7, use "magick" instead of "convert" or "magick convert"
convert: no images defined `C:/Users/Josh/images/imagemagick2_304.jpg' @ error/deprecate.c/ConvertImageCommand/3368.
ERROR: Processed failed with exit code '1'
is there a specific reason why it would fail? As far as I can tell the file format is supported.
https://www.imagemagick.org/include/formats.php [www.imagemagick.org]
Any pointers are welcome. Is there other tools that are commonly used to convert raw iamge files in TOPs?
Josh
