How do you make Shockwaves (on RBD)?
   172   1   2
I want to learn how to make shockwaves, so I go to google "how to make shockwaves Houdini", and the results give me Shockwaves... in Pyro Sim.
And I don't want Pyro simulations.
I want shockwaves as in waves that shock against objects, I want to RBD shockwaves.
I.E., I want ways to break, shatter and apply force to RBD objects without having another RBD object just to do it.
Like, I could not find anything when I was doing one of my scenes, so I just animated a sphere expanding rapidly inside the RBD geo i had, it get the effect I wanted actually, but I don't think that's the best way to do it.
I also used a Wind force DOP Node, it worked but it wasn't the effect I wanted, it pushed the geo away from the center, I tried other forces but I can't seem to make they work in my DOPs.
Looking through the SideFX tutorials, the one with the bomb exercise, I see they used I think the node "AttributeAjustVector", but it wasn't clear how they were timing the node to have the effect at the right frame, and they used in SOP (I think after a SOP materialfracture and before a SOP fracturesolver, on the Proxy geo Stream), I'm running things in DOP.
I could try this but is there any other way to make RBD objects shatter, break "on command"?
- maybe the metaballs is what you are looking for
and good tutorial for a shockwave
One-Punch Man Impact in Houdini | Pro Houdini Tutorial
https://www.youtube.com/watch?v=W8QE34J-xPI&ab_channel=FxGuru [www.youtube.com]
