I have an FBX character that I am using with mixamo. I have the workflow setup using match pose, match points, etc. This is working and I can retarget the mixamo onto this imported FBX rig.
The problem is accessing the blend shapes. If I import the FBX using the import dialogue (enabled import blend deformers as blend SOP on import), I can dive into the subnet and find the character node, in here the blend shapes are setup and working.
If I use FBX character import SOP and then wire into character blend shape extract, I can see the blend shapes in the pop up list, but regardless of which shape I choose, the geo stays the same and doesn't show the actual blend shape being referenced.
How do I access the blend shapes using FBX Character Import?
Thanks for any suggestions.
cheers
Tim
Cannot access FBX blend shapes
146 1 1- helloluxx
- 11 posts
- helloluxx
- 11 posts
Can anyone help a poor 3D artist solve this?
I am unsure of the correct way to wire this up and I'm sure that is what I've done wrong as the blend shapes geo is definitely in the FBX file.
If someone could offer any advice or even a screenshot of an FBX imported and the blend shapes set up.
I have a more complex setup with mixamo and retargeting but here is my simple node setup to import FBX Character and try to use blend shapes. Can anyone tell me what is wrong please?
Thanks Houdini Gurus.
