Unable to select more than 15k prim in 20.5
   149   3   2
Hi, I recently installed 20.5 and facing an weird issue: I am unable to select more than about 15k primitives in the Scene View. See video attached. This does not happen in 20.0.
I uninstalled/reinstalled multiple times. Windows is up to date and my Nvidia drivers as well.
Is that a know bug? Your feedback would be appreciated. Thanks.
Config: Window 11 Pro 24H2 / RTX 3080 / AMD Ryzen 9 7950X3D
bandicam 2024-11-22 09-57-46-742.mp4 (7.4 MB)
It's not limited to this number. Looks either like a bug, or maybe some setting is enabled that limits the number of selected components (though I'm unaware of any means to do it).
In any case, I cannot reproduce this issue (20.5.407). Maybe backup your user preferences and see if it happens with factory defaults?
Yep, same behavior for me with the Vulkan viewer, works fine in OpenGL if you need a temporary workaround.
The best thing to do is submit a bug report with your screen recording.
Ah, indeed. I switched back to Vulkan and now I see it.
