Hi!
I try to find a way to remove all zeros of a float before the first number which isn't a zero.
The float is a prim attribute.
Ex.:
0.000000000135 -> 135
0.456 -> 456
0.0000567 -> 567
0.01 -> 1
The count of zeros is variable.
Any idea?
Thank you and greetings!
Removing zeros from the start of a float
128 1 1- TubeSmokeGuy
- 22 posts
- alexwheezy
- 302 posts
You can do it this way:
or
// 0.000000000135 -> 135 // 0.456 -> 456 // 0.0000567 -> 567 // 0.01 -> 1 float input = 0.01; float value = input * pow(10, abs(ceil(log10(input)))); int n = -1; float eps = 1e-9; while(value - floor(value) >= eps) { value *= 10; ++n; } int result = int(value);
or
float input = 0.01; float value = input * pow(10, abs(ceil(log10(input)))); int result = select(value < 1.0, atoi(sprintf("%g", value)[2:]), int(value));
Edited by alexwheezy - yesterday 12:32:51
