Having troubles with the Channel SOP
   Views 604   Replies 2   Subscribers 0
Hey there,
I'm trying to import a channel into the channel sop and the channel that I have is called "left". When I try to set the Method parm to "Animated", an error pops up see picrel. I tried to rename the "left" channel to "left0" and that updated the error to
"Error: Channel left00 not found."
Any ideas?
Edited by andehpandeh - Nov. 26, 2024 16:24:37
brokenChannel.hiplc (155.5 KB)
Updated your example to work with "animated", As far as I am aware and according to the docs animated works
with "point" location or attributes
So how?
Import the "point" values over time into chops using a geometry node set to animated, then adjust the channels inside
chops and pull back using the channel node in sop set to animated.
Lots of fun to be had with chops but it sure is confusing and really lacks docs and good tutorials.
brokenChannel2.hipnc (178.1 KB)
Thanks so much EZ! I watched a few different tutorials and still couldn't get it to work, much appreciated
