Is there any way to dynamically set a ramp parm with Python
   440   2   1
The ch reference to a ramp works suprisingly well. However, since I need to control a ramp with raw data, in this case a dictionary attribute stored on a point, I'd like to instead control this ramp with a python expression. This is pretty straitforward with other parm types, I realize a ramp has its difficulties being a nested parm of sorts.
I would hope this would work, but, it doesn't ...
rampEval = hou.parm(pathToParm).evalAsRamp()
return rampEval
Aloha
Can you post File
Dict.hipnc (96.4 KB)
Conservation of Momentum
I'm not able to post the file, but, the task is fairly simple. This file works great computing the end result, I'm aware of how to use chramp, hou.Ramp.lookup() etc. The issue is to actually reference on to a ramp parameter.
Here's a scenario with a python expression on a float parm.
value = 3.33
return value
Here's a hypothetical value with a python expression on a ramp parm.
ramp = hou.parm(pathToADifferentRamp).eval()
return ramp
If I were to channel reference pathToADifferentRamp to the ramp I'd like to control, it would indeed work. However, a Python return of a ramp object won't. Any solution or hack for this?
