Cannot find Cross Product VOP node
   380   4   1
Hi there,
I don't know why but I cant find the cross product node in VOP context.
I can find the other nodes no problem.
I repair the houdini install but still the same.
Any ideas ?
Houdini 20.5.410
Win 10
Thanks for your help.
many reasons can be for this behaviour but can you create a node using Python?
hou.node("/obj").createNode("geo").createNode("attribvop").createNode("cross")
Thanks for the suggestion.
I'm not able to create the node with python either.
Here is the result:
  File "<console>", line 1, in <module>
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.410/houdini/python3.11libs\houpythonportion\ui.py", line 1182, in decorator
    return hdefereval.executeInMainThreadWithResult(
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.410/houdini/python3.11libs\hdefereval.py", line 45, in executeInMainThreadWithResult
    return _queueDeferred(code, args, kwargs, block=True)
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.410/houdini/python3.11libs\hdefereval.py", line 104, in _queueDeferred
    raise exc_info[1]
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.410/houdini/python3.11libs\hdefereval.py", line 155, in _processDeferred
    result = code(*args, **kwargs)
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.410/houdini/python3.11libs\hou.py", line 15443, in createNode
    return _hou.Node_createNode(self, node_type_name, node_name, run_init_scripts, load_contents, exact_type_name, force_valid_node_name)
hou.OperationFailed: The attempted operation failed.
Invalid node type name
I think you have changed the definition of this node. The easiest solution would be to backup the houdini20.5 folder in your home user directory and start Houdini again.
Thank you, I can find it now.
