OP_ERROR MapResample::cookMySop(OP_Context& context) { OP_AutoLockInputs inputs(this); if (inputs.lock(context)>= UT_ERROR_ABORT) return error(); fpreal now = context.getTime(); duplicateSource(0, context); setVariableOrder(3,2,0,1); setCurGdh(0, myGdpHandle); setupLocalVars(); fpreal target = evalFloat("target", 0, now); target /= gdp->getNumPoints(); GA_RWHandleV3 pos_h(gdp->getP()); if (!pos_h.isValid()) return error(); UT_Array<GA_Offset> pointsToDelete; GA_Range pts_range = gdp->getPointRange(); GA_Size numPoints = pts_range.getMaxEntries(); for (GA_Iterator it(pts_range); !it.atEnd(); ++it) { GA_Offset ptoff = *it; GA_Index idx = gdp->pointIndex(ptoff); myCurPtOff[0] = ptoff; if (idx ==0 || idx == numPoints-1) continue; UT_Vector3 curPos = pos_h.get(ptoff); if (idx + 2 >=numPoints) continue; GA_Offset nextOffset = gdp->pointOffset(idx+1); UT_Vector3 nextPos = pos_h.get(nextOffset); GA_Offset secondNextOffset = gdp->pointOffset(idx+2); UT_Vector3 secondNextPos = pos_h.get(secondNextOffset); UT_Vector3 edge1 = curPos - nextPos; UT_Vector3 edge2 = curPos - secondNextPos; UT_Vector3 crossVector = cross(edge1, edge2); fpreal area = crossVector.length() /2.0f; if (area< target) { pointsToDelete.append(ptoff); } } for (GA_Offset i = 0; i < pointsToDelete.size(); i++) { gdp->destroyPointOffset(pointsToDelete(i)); } resetLocalVarRefs(); triggerOutputChanged(); return error(); }
HDK local variables and updating the Viewport
170 0 0- getuffassassin11
- 7 posts
Hello, I have been trying to implement a resampling function with the hdk. I used the SOP/SOP_Flatten.C example as a reference which has a helpful comment about using local variables and the viewport. However, I still cannot get the viewport to update when deleting points, i.e, updating my parameter. I can see the geometry spreadsheet update, but when the display flag is on the C++ node, the viewport does not update, I was wondering if anyone has encountered this issue and has any suggestions. Any help?
Edited by getuffassassin11 - yesterday 03:44:35
