This topic has been brought up in several posts but I am still having some questions for specific workflows, even after watching Mark Tucker's Hive presentation.
What would be the best performing approach for the following example?
Given a user given pattern of thousands of primitives, we have to run some checks accessing to some of its attributes. If the check is successful we create n references per primitive with data fetched from the original primitive.
I would instinctively do as follows;
read_stage = node.inputs()[0].stage()
write_stage = node.editableStage()
for path in paths:
# Read attribute per prim from read_stage
# Write: Create References in write_stage
This has never printed a warning and I have never felt a poor performance. However, members of SideFx involved in Solaris have repeatedly told me this is dangerous and potentially worse performance wise, because of how the stage locks work.
What I was told would be something like this:
# Read
for path in paths:
# Read attributes
# Store in arrays all needed data.
# Write
for path in paths:
# Access the arrays for the necessary data
# Create references
My question here is, even when we are dealing with thousands of paths and accesses, is this second approach better in performance? How is the first approach dangerous?
