how to control RBD debris simulation? :'
   Views 895   Replies 2   Subscribers 1
hey guys! I've just recently started on learning FX with Houdini so pls bear with me :S
I'm adding secondary debris simulation for the fracture but it's confusing to control. Currently the debris feels like going everywhere and went up so high. I searched up online and they mentioned to add height limit using VEX but I'm not sure where to add the wrangler, I tried few times and didn't really see the differences. Also, is there a way to keep the debris simulated only from above the ground, not below it? Thank you!!
debris_outofcontrolhelp.hip (1.5 MB)
That doesn't happen using H20.5. Try upgrading from 19.5 to the latest version.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
Okey noted!! I'll try to update the version. Thanks for the help!
