I don't know why even the source mesh is meshed together
291
2
1
Dec. 30, 2024 4:26 a.m.
Hello.
I'm making a splash with flip.
When I use particlefluidsurface node, it convert with source mesh.
I don't know why.
I attached my hip file.
I would appreciate it if you could take a look.
hip_file.hip (768.6 KB)
Enivob
Dec. 31, 2024 9:58 a.m.
That's the particlefluidsurface node's function. It makes a mesh. Delete it from your network to avoid mesh creation.
Using Houdini Indie 20.0 Windows 11 64GB Ryzen 16 core. nVidia 3050RTX 8BG RAM.
tamte
Dec. 31, 2024 5:21 p.m.
it's because your dopimport1 is also importing the surface field you can append Blast SOP, type particles into Group parm and check Delete Non Selected to keep only particles for meshing
Tomas Slancik FX Supervisor Method Studios, NY
