Would Rewriting Houdini’s VEX Using C++20 Significantly Boos
   385   4   1
what if VEX were reimplemented using C++20? Would it lead to noticeable performance improvements in terms of compilation
Edited by medicine - today 03:32:46
While I can't speak to how or whether using c++20 or c++23 would affect performance or compilation time
Houdini tries to follow VFX reference platform [vfxplatform.com] for maximum compatibility, and that still suggests c++17 even for 2025
Edited by tamte - Jan. 3, 2025 10:21:17
FX Supervisor
Method Studios, NY
Rewriting VEX in C++20 wouldn’t make much difference in performance IMO. VEX is already optimized for Houdini, and runtime or compilation speed gains would be negligible. The real performance improvements would come from changes to the VEX compiler and addressing current bottlenecks, like:
Batch Attribute Access: Fetching attributes one by one is a major slowdown. Functions to fetch multiple attributes at once would reduce overhead significantly.
Geometry Creation: Creating geometry in VEX is much slower than with HDK. Optimizing this process would bring massive performance gains IMO.
Compiler Optimizations: Smarter optimizations at the compiler level, like better vectorization or reducing redundant operations, would yield much bigger benefits than switching to newer C++ versions IMO.
Right now with complex code, matching, approaching, and sometimes surpassing C++ speeds with VEX requires a lot of tricks and a deep understanding of how to write highly optimized VEX code.
tamte
That's very helpful. I will explore this website. Thank you
Edited by medicine - today 04:08:58
animatrix_
Thanks for the professional response
Edited by medicine - today 04:13:44
