Particles Color from Object
   170   3   0
Hey All,
Im still very new to particles so Im doing some experimenting. Can someone point me in the direction of how to get my particles to get their color from my model? Right now I have them set up to get their colors from a color ramp.
Im on Houdini 20.0.688
Edited by vishnu1024 - Jan. 2, 2025 11:06:42
Screenshot 2025-01-02 at 11.05.59AM.png (569.4 KB)
Make sure your particles inherit uv attribute from the can
Then use Attribute From Map SOP to sample the same texture you are using on the can
FX Supervisor
Method Studios, NY
tamte
Thank you very. I'll give this a try. The can has several materials on it, would I need to put all of them on one uv/ Texture sheet?
Not necessarily, there is a plenty of ways you can approach it
Id probably store texture path as an attribute on the can geo so that the particles inherit it also
To do this you can either assign it in SOPs to the same elements as your materials
Or you can do a small Python SOP to extract the texture paths based on materials assigned through s@shop_materialpath attribute
Then you can use something like
v@Cd = texture( s@texture_path, v@uv.x, v@uv.y );
To sample the color in VEX
FX Supervisor
Method Studios, NY
