hotkey for Char vis in APEx animation
   Views 721   Replies 2   Subscribers 2
hello folks!
Id like to make my self a hotkey for turning on and off the character visibility in the view scene for houdini 20.5.410, but i'm not a script person at all and i am very new to houdini. Anyone else know how i might accomplish this? I like to speed up my workflow using hotkeys rather than constant menu clicking.
thanks in advance
Patricia.
Sorry for the late reply here. The scripting API is still very much in flux but if you create a shelf tool, then you can assign a hotkey to it for this code:
from apex.ui import statecommandutils as scu
from apex.ui.selectionmanager import utils as ssu
model = ssu.retrieveModel()
chars = {}
for p in scu.findSceneDataPaths('*.char'):
    c = scu.getSceneData(p)
    if not c.isVisible():
        chars[p.split('/')[-1]] = {}
ssu.sendCharacterVisibility(chars, model)
The main problem will be finding a hotkey that works. On a quick try, Ctrl+F2 assigned at the global scope was the first thing that worked for me.
Edited by edward - Jan. 27, 2025 16:14:13
PS. For the next major release, there will be some default available actions so that a script will not be needed.
