Newbbie question on missing shelves
3781 4 1- kinglaw
- 9 posts
Im new to Houdini ive mostly worked in Maya. ive installed houdini and its running fine trying to follow some begginers tutorials from the getting started series. only problem i got is that the default shelf is missing(the one with all the primitives like the sphere,cube etc). what should i do to get Houdini running with the default settings? Help!!!!!!! i have attached a screen shot of the error to this message
- Doudini
- 333 posts
what happens if you change your desktop back to the standard build or some others?
Windows -> Desktop -> Build
Otherwise there is a “Plus” sign in the shelves that will let you add it
“Shelves -> Create” is the one.
if it doesnt help, maybe erase the houdini13 folder might help. its in the users home folder.
edit: i just saw your screenshot and i dont know what it means tbh, but try reset the houdini13 config folder as mentioned above. you can erase it and houdini should make the files once you start it up and set things back to default.
- kinglaw
- 9 posts
- edward
- 7745 posts
- kinglaw
- 9 posts
