I'm trying to run Hqueue on a local machine as a server, but I'd like my server to also be a client.
I'm on windows… I have both server and client installed, both server and client are running as services. Server is resolving, but shows 0 clients. Is there something custom I have to do on a windows machine to get it to show up as a client when both are on the same machine?
Thanks.
How do I get my Hqueue server to show up as a client on the same machine? (on Windows)
2302 1 1-
- patrickkrebs
- 4 posts
- goldleaf
- 4253 posts
Hey, I don't have access to a working Hqueue at the moment, nor have I used Windows as much. However, from the installer, you should be able to reinstall the client, and point it at your machine as the server.
Are you using the machine's hostname, or just localhost? I'm not sure if localhost would work (I haven't tried that), but if you are using it, maybe try using the machine's name?
I'm o.d.d.
