Focus on object
   25833   19   2
I have got a really silly question but I couldnt figure it out yet. I want the camera to stay focused on a specific object, even if the object or the cam is moving. Is there an easy one-klick solution?
It's not exactly one click, but there's a Look At parameter on the Camera object. Select the object that you want to look at and it'll do the rest. It won't auto-frame the object, though.
Hey,
and this will set the focus sweet spot automatically onto the object?
twod
What if I want to control the focus but I don't want to change camera's constraint?
In other words, I still want to control cam pos, rot, without pointing at any particular object in the scene, but I do want to control the focus distance (as if I were changing focus on my camera using the lens' focusing ring).
An example for this comes from Blender:
Andrew
Houdini Apprentice
on the Sampling Tab of the camera object there is a parameter called Focus Distance
NOTE - this will only work when you have Depth of Field turned ON
if you select the camera and hit Enter in the viewport you'll get the handles for the camera, then use the “z” hotkey
now you'll have a little square thingy and two arrow thingys
move the square thingy to the distance you want to focus and the arrows to narrow the depth of field
I made a little file to show you one way to have more control over the two main parameters you need to adjust to have focus track an object
I built a geometry object and inside I merged in the camera origin and the center point of a null object
I made a poly line with those two points and the measured it's length
I then used a prim() function on the Focus Distance Parameter of cam1
now I can place the null object - called “focus_target” anywhere in the scene and that will drive the focal distance…which doesn't seem all that great…but if you unparent the null from the camera it can now become a child of anything in your scene…and if it's a moving object the focal distance will update as needed.
the other parameter you need to adjust is the F-Stop - large values mean a deep focal distance, small values mean a very tight range that will be in focus.
in the ropnet the mantra node has Enable Depth of Field turned ON.
you can make this way better of course…but it's something to play with
and you should check this out:
https://www.youtube.com/watch?v=01UlqkRRcgQ [youtube.com]
HTH
focus_distance.0.hipnc (794.1 KB)
Training Lead
www.sidefx.com
lol, that much effort for a focus track In other software packages you just have to drag and drop the tracking object in a slot. As much as I love Houdini, some simple things should just be easy. But thanks for the answer!
Thank you so much Michael,
great setup and good to know this is possible with Houdini.
Thanks for the detailed explanation.
Andrew
Houdini Apprentice
you can just put following expression to Focus Distance parm without any extra steps
vlength(vtorigin(“.”, “../focus_target”))
it will measure world space distance from camera to focus object (in this case named focus_target in the same level as camera)
tamte
Thanks,
that's very handy!
Andrew
Houdini Apprentice
Thanks, thats great!
So long story short, there is no Maya F type function? You all are going on and on about coding F stops and random stuff but it's really a simple question. Can you focus the camera on something or not?
Matt Slanchik
this thread is about a camera's focus - not what applications refer to as ‘focus’
if you want to snap the camera view to a selected Object - use ‘f’
Training Lead
www.sidefx.com
Hey Everybody,
this method is not working in houdini 16 anymore. Can somebody give me the right vex/expression that i can put into Focus Distance to focus on an object?
Thank you!
CYTE
this seems to work in 16, but I'm not sure it's the best way
distance(ch(“tx”),ch(“ty”),ch(“tz”),ch(“../CameraTarget/tx”),ch(“../CameraTarget/ty”),ch(“../CameraTarget/tz”))
Chris
CYTE
It's still working but the comma needs to be in ascii (").
The correct code is
vlength(vtorigin(".", "../focus_target"))
Edit by ndickson: Fixed forum text formatting
Edited by videlam - Nov. 16, 2017 06:48:49
Hey videlam,
wow thank you!
I made a script to create a null and set the focus on it.
On the shelf, create a new tool and copy/paste the code
import toolutils
scene_viewer = toolutils.sceneViewer()
selected_objects = scene_viewer.selectObjects("Select a camera and press Enter",allowed_types = ["cam"])
object = hou.selectedNodes()
netparent = object[0].parent()
selectname = str (object[0])
focus_obj = netparent.createNode("null", selectname+'_focus_target')
d_focus=('vlength(vtorigin(".", "../'+str(focus_obj)+'"))')
hou.parm('/obj/'+selectname+'/focus').setExpression(str(d_focus))
This vector length to focus distance expression works fine in SOP's - but can anyone provide a step by step method of getting this to work in Solaris?
I have the same issue, with not getting it to work in Solaris. Any help appreciated.
I realise this is rather late but I've found videlam's bit of code really useful for creating a focus object for Karma.
I too wanted to get use it in solaris and having watched some of solaris essentials
https://www.sidefx.com/solaris-essentials-lops-karma-matx/ [www.sidefx.com]
I realised a way - use the code above to create your focus object and then when you go to solaris use stage or create a lopnetwork, then use scene import(all) for your whole scene or scene import (camera) import to bring in your camera - and it will include the focus distance to the object. If you go back to object context and fiddle around with the focus object - back in solaris it will update. It works animating the focus object for focus pulls etc.
This is probably really obvious to seasoned users but as someone who has just started experimenting with Karma it is not. As this topic is what I found when searching for karma focus object it might be one other people's first result.
Hope that helps someone.
