What different for bgeo and bgeo.sc
   19092   4   1
I tried with simple curiosity.
same sim but ‘Bgeo’ and ‘bgeo.sc’, respectively.
bgeo.sc
: long cache time
: but small cache size
bgeo
: very short cache time
: but cache size too big batter sc
However, when I import the file, the viewer does not know the difference at all,
and the spreadsheet has the same properties.
What is the difference between the two extensions?
Is there any information I can refer to?
Greeting.
Please check mark's post here:
https://www.sidefx.com/forum/topic/37510/?page=1#post-171095 [sidefx.com]
Edited by Nima - Feb. 9, 2017 06:49:05
Nima
Greeting.
https://www.sidefx.com/forum/topic/37510/?page=1#post-171095 [www.sidefx.com]
What use case would we use compressed "bgeo.sc" over regular bgeo? What information is bgeo.sc lacking?
mannyw
Nima
Greeting.
It's not lacking any info, it's a lossless compression similar to zip, which you can also do using bgeo.gz
The aim is to get lower size cache at the expense of slight compression time cost
Having smaller files can also mean faster network transfer that can compensate for compression time, etc
CG Supervisor
Framestore, NY
tamte
I would guess in most "production" scenarios (for lack of a better word), with centralized storage it will be just like you said. .sc compression on modern CPUs is so negligible compared to everything else involved. One will see the benefits even on smaller scale projects.
Martin Winkler
